Products Discussions
Share best practices and get the latest Microsoft product info
BR
Unable to connect or remotely access Hyper-V guest VM.
Working with a windows 2016 vm which is a domain controller that for a while has not allowed console logins via Hyper-V nor remote logins.
Using Hyper-V Connect gui shows the locked login screen and clicking on ctrl-alt-delete button flashes the screen but the login prompt does not show. Remotely accessing via RDP, you get prompt for credentials and after entering creds it looks to log you on but then cononection closes out before you actually successfully are logged in.
The VM is a node on a failover cluster with virtual machine version 9. At the inception the vm was part of an older standalone hyper-v host. You can ping it and it appears to be operating normally as one of several on premise domain controllers. Also we have access to it via powershell direct from the hyper-v host. Looking at the event logs does now show anything obvious.
Has anyone seen this behavior and have a solution to resolve logins via the GUI?
Bob
DSPatrick
Level 6 Contributor
The cleanest / simplest / quickest solution is to turn it off, seize roles (if necessary)
https://support.microsoft.com/en-us/help/255504/using-ntdsutil-exe-to-transfer-or-seize-fsmo-roles-to-a-domain-control
then do metada cleanup
https://docs.microsoft.com/en-us/windows-server/identity/ad-ds/deploy/ad-ds-metadata-cleanup
and stand up a new one for replacement.
