Connect-MgGraph secure application model and GDAP
I am trying to get a token for a partner set with GDAP so I can then use it with connect-MgGraph
The below works fine for DAP partners :
$ApplicationId = "My application id"
$ApplicationSecret = "My app secret"
$RefreshToken = "My refresh token"
$AuthBody = @{
client_id = $ApplicationId
client_secret = $ApplicationSecret
scope = 'https://graph.microsoft.com/.default'
refresh_token = $RefreshToken
grant_type = "refresh_token"
$tenantid = "Partner tenant id"
Invoke-RestMethod -Method post -Uri "https://login.microsoftonline.com/$($tenantid)/oauth2/v2.0/token" -Body $Authbody
However it returns
AADSTS65001: The user or administrator has not consented to use the application with ID '########-ffd6-48b7-aa6d-############' named 'AppName'. Send an interactive authorization request for this user and resource.
I am able to connect to exchange for GDAP partners but not Microsoft Graph. Particularly the MGGraph powershell module. It works fine with DAP.
Can anyone help?
Development Platform & Tools
I've been in contact with the internal team and they suggested submitting a support ticket for each instance as it sounds like a technical issue that requires some investigation from the technical team.
https://aka.ms/technicalservices.
If anyone gets a solution will they come back and let this string know? Thank you!
We are observing the same problem since we've changed DAP to GDAP for some of our Customer-Tenants. However, calls concerning the PartnerCenterAPI can be successfully send and received. Otherwise all operations concerning the MS graph API are returned with the Error:
"AADSTS65001: The user or administrator has not consented to use the application with ID '########-######-###-####-############' named '<OurAppName>'. Send an interactive authorization request for this user and resource."
Any help would be appreciated.
@MatStretcher and @Glenndsq ,
Just wanted to reply because this thread was one of the few hits I had for GDAP and your error, AADSTS65001. I believe the problem is that Microsoft changed the GDAP delegated permissions model between late August 2022 (when I initially tested DAP -> GDAP and it all worked) and early October when you two, and @ClaudioStallone encountered this error.
SOLUTION:
In another thread in this Partner Center forum @JanoschUlmer posted a solution that @ClaudioStallone confirmed. I just tested it and it works, including for Connect-MgGraph, you can see my reply here, which in the same thread, including a confirmation from Kelvin.
It shows how you will need to add a Consent for your Secure App Model in the Customer's tenancy. I also found that Exch Online works, but for Azure AD, Graph, and Azure the steps in the post (originally from Janosch) are required.
I hope that helps!
@Glenndsq @ClaudioStallone I don't know anything about this, but I am inquiring within to see if I can find someone to help. I'll let you know if I find out anything! Sorry for your troubles here.
Hello @v-jillarmour
Thank you very much, we also have create a MS Case for that TrackingID#2210040040003176
As it is very urgent for us, as our automations using Azure as well as MS Graph are no longer working for GDAP customers!
We have the same issue since this week!
