TommyDK
AI-Builder
When the AI-Builder trial expires, should it be replaced by the AI Builder Capacity add-on or is Power Automate per user with attended RPA plan / Power Automate unattended RPA add-on enough?
It is used for an OCR flow that reads PDF documents automatically and manually
Best Regards
Tommy Jørgensen
phil-msft
Sorry for the late answer.
Power Automate per user with attended RPA  grants 5K credits per license.
You should assess with  AI Builder Calculator if this is enough for your use case or if you should purchase additional AI Builder addons (See https://flow.microsoft.com/fr-fr/ai-builder/ )
Regards
