Products Discussions
Share best practices and get the latest Microsoft product info
SandipSaha
iSCSI target max
Daer Member,
Is there a limit to the number of ISCSI target ,
we have 2 number of iscsi LUN over microsoft cluster server and those assing to 16 number of Esxi host. But problem is after
8 host its not support
windows 2016 storage server (Hpe Storeserv )
esxi 6.7
PerWerngren
Influencer
Hi Sandip,
I am not a technical engineer but I remember that there is some kind of limitation (but I believe it is for the number of concurrent active connections). My suggestion is that you either file a support ticket (using one of the support incidents that you have in MPN) and/or that you contact the hardware vendor (HP in your case) as they will probably be able to help you. I find HP being great to work with!
Regards, Per
SandipSaha
Hi Per,
Thanks For reply we have configure concarrent active connection to all my esxi hosts but as i say only 8 host are connected.
i need to know any limite on IScsi terget LUN
Sandip
