Products Discussions
Share best practices and get the latest Microsoft product info
Skype for Business Cloud Connector installation issues
Hello
I encounter an error when installing the Cloud Connector (Install-CcAppliance) Version 2.0.1:
Creating base virtual machine...
Starting base virtual machine...
Operating system started in 3375 seconds.
Got virtual machine IP: 169.254.66.143
Enabling credential delegation for NTLM on host machine.
Creating key on host machine: hklm:\SOFTWARE\Policies\Microsoft\Windows\CredentialsDelegation\AllowFreshCredentials
Creating key on host machine: hklm:\SOFTWARE\Policies\Microsoft\Windows\CredentialsDelegation\AllowFreshCredentialsWhenN
TLMOnly
Create-BaseVM : The configuration of the operating system has taken longer than usual. Check the virtual machine
network configuration.
At C:\Program Files\WindowsPowerShell\Modules\CloudConnector\Initialize-CcHost.ps1:182 char:5
+     Create-BaseVM -INI $ini -VHDPath $vhdFilePath -UnattendISOPath $u ...
    + CategoryInfo          : NotSpecified: (:) [Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,Create-BaseVM
Is this issue known?
Do you have any ideas what might be wrong?
I highly appreciate your help!
Thank you!
Hi Patrick,
Thank you for your reply
Did you see this error in your experience?
