WolfKPCS
Secure Score only for Licensed Tenants
Hi, in the https://docs.microsoft.com/en-us/partner-center/partner-security-requirements#assessing-your-environment you mentioned that Secure Score is available to check the MFA result also with sign-in logs in AAD.
Just to be clear, without licenses in tenant (like Sandbox) Secure Score is blank and show no data. And sign-in logs are available only in per-user, only with AAD Premium, there is unified log or option to look in Identity Security Score.
idwilliams
@WolfKPCS the PowerShell script that is included in that section will pull the sign-in activites for each user. That does not require any license and that information is available in all environments. Considering the Secure Score information is not present in your integration sandbox, I would recommend using the script approach.
