Microsoft Partner Network
Where Microsoft's CSP, MSP, SI, and ISV partners seek new opportunities and learn from each other
PAL assignment does not work?
Hi All,
I'm dealing with the following issue - when I'm trying to link my Azure account with customers tenant using PAL I'm getting the following error:
new-AzureRmManagementPartner : Operation failed with message 'The Partner ID is not valid'
PowerShell code I'm using:
Connect-AzureRmAccount -TenantId <tenant id here>
new-AzureRmManagementPartner -PartnerId <MPN ID here>
Anyone has ever seen this error? Am I the only one hitting this problem with PAL?
Thank you,
Pawel
Be sure not to use the ID of the virtual org, but an ID of a location or the HQ. You should be able to see the IDs in Partner Center under Settings - Organization settings
