Microsoft AppSource and Azure Marketplace
Learn how to grow your business by publishing your cloud solution on Microsoft AppSource and Azure Marketplace
jyotikhule
Azure Marketplace SaaS integration - need help
Hi all,
Hopefully I am posting in the right community.
We are stuck with SaaS integration and really looking for community wisdom to help us
To summarise the issue, we have integrated with SaaS fullfilment API v2 using the documentation link below. On step1, user is directed to our landing page with token on subscription request. At per documentation, our application calls RESOLVE api to get subscription details. However, resolve API is returning error 400 with following JSON:
"message": "Subscription resolve not found",
"target": "subscriptionId",
"code": "EntityNotFound"
We are not able to find a cause of the error and getting bit clueless. Can anyone please help or point to right documentation? It will be great if we can chat with someone who has successfully integrated with SaaS commercial marketplace.
Many thanks for the help.
Links:
https://docs.microsoft.com/en-us/azure/marketplace/partner-center-portal/pc-saas-fulfillment-api-v2
3 REPLIES 3
code4clouds
ngroot
Ensure that you're sending a POST, not a GET.  There appears to be a GET version of the endpoint which always returns this error.
Manesh
v2 API integration works well for us. May be I can take a quick look at your issue and guide you if needed.
