danielnogueira
How can ASfP help you, accelerate innovation through Private Azure Marketplace
Dear Partner
Did you know that Apps can be added from Azure Marketplace into the private Azure Marketplace that complies with customer policies and standards?
Company employees can then easily buy or deploy these pre-approved apps within the organization. Microsoft apps are automatically added to the private Azure Marketplace. In addition, customers with an Azure consumption commitment can deprecate it by purchasing eligible apps through Azure Marketplace.
If you are a non-managed Microsoft Partner with Advance Support for Partners(ASfP), contact your SAM and ask to be engaged with the Cloud Enablement Desk (CED).
CED will help you onboarding to the commercial marketplace​. They will explain you the commercial marketplace opportunity and different listing types, guide you through solution listing process and provided ISV Resource Hub Product and solution area playbooks, documentation and developer guides.
If you don't have ASfP, don't worry, contact @rob_roggeveen
0 REPLIES 0
